81 35hp seahorse coil questions
1964jetstar
Can the charging ignition coil have an intermittent problem? All test say its ok when running cool, good spark. Power pack and ignition coils are new. The charging coil and sensor coil ohm out to spec when cold. Would it be more likely for the sensing coil to malfunction or the charging coil when running up to temp. Anyone have experience in this area. Also can not find anyone who stocks these parts. Only ebay on occasion.Thanks
jonesg
Re: 81 35hp seahorse coil questions
What are we talking about here, the stator ?
What are the symptoms , you haven't explained the problem yet.
bktheking
So take a hair dryer and heat each component up and re measure.
1964jetstar
This is a capacitor discharge igniton. there is a charging coil and a sensor coil under the flywheel. (wich I have not removed yet). The motor will start and run fine at idle. Will run great at wot for about 7 minutes then will just cut out completely. No spuddering or advance warning. Took it back to the marina and had their tech check it out. he told me it was making strong spark. The compression on both cylinders was 135.(wich i thought a little strange). He thought is was a fuel problem. after a week in the shop and cleaning the carb I just rebuilt, he suggested it may the fuel pump. Told me he ordered a check valve and it would cost me about 300.00. I told him to zip it up and I would come get it. I do own the factory service and parts manuals for this motor. there is no check valve on this fuel pump. It works with a diaphram using crankcase pressure. Anyway,just in case It cost me 47.00 from Iboats and took about 10 minutes to install. So I can rule that out. As i stated the power pack and ignition coils are new and it sure has the signs of being an ignition problem. All connections have been double checked. So that pretty much is all that is left. As was sugested I could use a hair dryer and heat the componets up and ohm them out hot. But I would have to take off the flywheel first. I guess thats my next step. After buying a puller and a torque wrench of course. Any other suggestions would be appreciated.
