fishon1213
Thread starter- Joined
- Aug 10, 2009
- 80
Yes, I know, birdseed!?!? I have a 1981 Johnson 15hp that I just put a lower unit on this spring, went to take it out for the first time and it was idling kinda low, went to throttle her up and she died and wouldn't restart.
Turns out a rodent of some kind stuffed my intake full of birdseed. I cleaned everything out of the breather box, took the carb apart and cleaned thoroughly, and changed the plugs. The reeds on this engine are not very accessible so i stuck a shop vac up to port where the carb bolts up and sucked out a weeks worth of food for a family of sparrows.
The engine has spark and will not fire even with 50:1 mix directly in the cylinder. My next step is compression test. I would like to take the reed assembly off but it looks like the only way would be to remove the powerhead. What is all involved in powerhead removal? I know this is a very odd problem but if anyone has any advice I would greatly appreciate it.
