81 Johnson 15hp Carb ?
hdodt
I have an '81 Johnson 15hp. I rebuilt the carb today and didnt mark the air fuel mix valve before I removed it. How far do I turn it out from fully seated? Also I was wondering if I should set the float to parallel with the carb body when its upside down? Any help would be greatly appreciated. Thanks...
D
bktheking
Re: 81 Johnson 15hp Carb ?
D
Parellel to the carb body is correct and seat the needle gently, 1 1/2 turns out should get you started. Fine tune it from there.
