metriccrescentwrench
Thread starter- Joined
- Oct 22, 2007
- 2,598
1981 Johnson 90 HP. This engine runs flawlessly ALMOST all the time. Last compression check: 120 118 115 115. I put new spark plugs in 2 weeks ago.
Every so often when going slow (no wake speed) there will be an obvious drop in power (but yet it doesn't really run rough), then when I feed in throttle there will be very poor acceleration for maybe 10 seconds and then WHAM, it'll jerk your head back when it starts running on all cylinders again. This hasn't happened often, maybe 3 or 4 times in the past 6 months. The latest occurence was this past weekend, while idling away from the boat ramp. As has always been the case, after the one hiccup it ran great for the rest of an afternoon of pulling skiers and tubes.
Am I barking up the wrong tree in assuming this is an ignition related problem? Maybe a power pack?
I hate intermittent problems because it always seems like you end up throwing money away until you finally luck into the fix.
