guitarkev77
- Joined
- Jun 26, 2009
- 49
Re: 81 Sea Ray 26 Sedan Bridge I/O to OB Conversion/Restore (Pics)
Hi Kickback,
I've just read your entire thread from beginning to present tonight. It has been a fun read, and it looks you are doing very nice work! That boat will look sweet with twin 200's hanging off the back.
Regarding your question about straight-lining lumber, it is really a 2 step process. If you had a jointer, you could straight line one long edge on the jointer, then use that edge to run against your table saw fence to get a straight cut on the other side.
If you don't have a jointer, you can still get a straight edge, it's just a little more work. You need a perfectly straight board to start with, that is longer than the piece you are straight lining. Home Depot, (or better yet, a decent lumber yard) sells S4S (surfaced four sides) hardwood lumber that you should be able to pick through until you find a perfectly straight board. An Oak 1x6 works well, and you should be able to find one around 10' or so.
I would add a couple coats of wax to the board, and your table saw, buffed out. This will make it easier to rip your lumber.
Measure the width of your straight line board. Add this to the thinnest clean (you want a clean, continuous cut) width dimension of the board you are straightening. Set your rip fence to this combined width. With your straight line board against the fence, position the board to be straightened with the crown of the board on the blade side. Since the board is convex out, you will have two points that will sit against the straight line board. Run the board through the saw while holding it firmly in place against the straight line board, which is riding tightly against the rip fence of the saw. This will clean one edge of the board. Now, measure the narrowest dimension of the board and set your saw fence so it will take a 32nd or 16th past this. Run the board again with your newly cleaned edge against the fence. You should now have a straight board with edges that are parallel to each other.
I guess you could accomplish this with your router table set similarly to a jointer, with your out feed fence set to the depth of your cut, but you would still want to run the other side of that board on your table saw to ensure that your two edges are parallel.
Geez, I got a little long winded there... Hope this helps
-Kevin
Hi Kickback,
-Kevin
