Re: 82 35hp rude acts like it hits a log at half throttle
Once you have ruled out the gearcase check for fuel delivery issues.Next time you watertest the engine try pumping the primer bulb and see if it responds.If so you're fuel pump may be on its way out.If not ,try bumping the key primer(if equipped)repeatedly and see if the engine picks up.If so,you may have restricted carburetors.If not,perform a spark test at cranking speed with a well charged battery and insure both sparkplug leads will jump a 7/16" gap to ground with a crisp blue spark.<br /><br />As mentioned above,if the gear lobes are worn down,you still have a gearcase issue.Does the engine seem to increase momentarily in rpms when it is bucking?
