82 chrysler 140 outboard question?
gtownky
I hooked the motor up to water ears and do not see water coming out of the 2 holes about mid way up on the rear of the motor. Should I be seeing water there or any where else? I hope i am explaining this correctly.
gtownky
Re: 82 chrysler 140 outboard question?
Can someone help please?
Stanley1
Force motors do not have a telltale.
The two holes in the back of the leg will spray a small amount of water.
You can add a telltale. see link
http://forums.iboats.com/showthread.php?t=210027
I always found submerging the lower unit in a barrel of water works better to test. A large plastic rubbermaid storage bin works well.
Muffs do not seem to fit well on Force lower units.
You can test your thermostat in a pot of hot water.
Also you may want to put a hose in the thermostat housing and flow water backwards through the system to clear anything that may be blocking it.
