Not sure where to go from here . . .
I picked this motor up cheap a couple weeks ago, and have gotten it running, but can't seem to get water flow. It'll idle for 3-4 minutes, then gets hot and stalls.
So, I checked the impeller. I didn't find the pin (maybe I dropped it) so replaced that. The impeller was still in like new condition. Started the motor, got flow from the telltale, then was playing with the idle setting at the front of the motor. It got hot again and died. Must have lost water flow at somepoint. So I removed the cylinder head cover, removed teh thermostat, and didn't see anything blocking flow here. Replaced the cover w/o the thermostat and started the motor. Still no flow. So I removed the outer exhaust cover. I didn't find anything restricting flow here either.
When I turned the motor over with the starter and the plug wires off, there was water flow out of two openings coming from the block. I didn't find anything foreign in here either. I replaced the cover, restarted the motor, and again, no flow.
What am I missing? The impeller on this motor has an oddly shaped cutout for the pin. Is it possible to put the impeller in upside down? Could this be my problem? If so, then why the flow with the covers off? And I'm wondering why I had the visible flow for a minute, then it stopped.
What should I try next?
Thanks for you help.
Scott S.
Scott S.
