82 Starcraft MR 180 floor, slight refit and leaks
redneck joe
More OTF questions.
No issue letting cure standing on edge as long as I allow for air flow, correct?
@jbcurt00 since you suggested the MDO grade plywood - the OTF is not soaking in much and only looking 'thirsty' at the edges. Where I bought was old school supply yard so was in one of the barns but we'll covered and in my garage for a week so should be nice and dry. I'm guessing not taking too much because it is a higher quality product and more dense wood?
jbcurt00
Yep, that's why it's used for exterior road signs....
I used epoxy w MDO and it didn't absorb much.
redneck joe
10-4. Been about 45 min about to go wipe down.
Side note I will be putting the used rags in a paper bag in the driveway. Hope the cam will capture it igniting so we can post a PSA. and, well, it's a fire and I'm a dude......
redneck joe
First two are complete. Can only do one at a time now (two left) because sun it up and it's getting warm, only spave enough for one at a time in the garage.
jbcurt00
Nearly a lifetime ago I did hardwood floors,
Had to change to white commercial trash bags after a bag of sanding dust got left on the wood deck and stain rags were tossed in....
Next day sat in the full sun and started to smolder.... charred a nice 2.5ft circle on the deck.
Homeowners were out of town, observant neighbors saw/smelled the smoke and hosed it off.
Also, dust/floor bin fires are a thing too...
In the winter don't shake out the dust bag on a sander up wind of a burn barrel.... flame travelled up the dust cloud....
redneck joe
Still no combustion...
Flipped third panel back over and letting another light coat sit for a few.
redneck joe
Filled up the front third to check for leaks. Hope no more because I just used my last solid manual rivet. Scrounged up from the working area.
redneck joe
Three hours full of water bow to stern, no drips.
All four flooring pieces OTF'd and curing for next 72 hours.
Based on tepefields post I am taking leftover bbq pork ribs, chopping it up and making loaded nachos for supper, one of the 'kids' last minute spending the night with apparent marriage issues so my job is to shut up and cook and fill wine glasses for the girls until they fall asleep on the couch and then make breakfast and bloody marys.
Tomorrow planting squash and opening the pool and power washing the inside of the boat one last time to prep for gluvit.
It was a good day.
Goodnight.
redneck joe
I decided about 10pm that the girls would be able to fend for themselves so off to bed I went. As usual for a man my age, about two hours later I get up to complete my old man rountine only to find them unpacking what turned about to be about 50 bucks of Taco Hell from door dash. Naturally, I joined them and yes it was just as horrible as one could imagine.
In other news, water overnight in the boat did end up with a wet spot about 2 inches across so I believe I am at the point of diminishing returns and hope the gluvit does its gluviting.
Totally unrelated..... the house down the road appears to have secured a peacock to add to the donkeys, dogs and chickens that announce the arrival of each and every morning. Yay us.
redneck joe
Unfortunately, no fire was started.
Ordered paint, primer and no slip rustoleum today. The otf should cured by Wed.
redneck joe
While brushing the rivets in prep for the gluvit, one popped and I decided to drill out three more.
Paint just got dropped off and after tonight's storms it will be low 70s day and low 50s nights so I'll be much more productive. I'm going to wait on the gluvit application so I have a bit longer working time.
redneck joe
Another otf question.
It appears I left too much on one side and let pool. Now it's kinda tacky. Will it continue to harden? Been four days. I had planned to paint the bottom side or at least prime so is that a bad idea and or will the primer stick?
redneck joe
So who the h... came up with mixing gluvit by weight and wtf does my mixing cup have EVERY ratio other than 5:1.
redneck joe
Well no gluvit today, they lied about high temp almost outand when I was doing final cleanup on the I thought back to the last couple three rivets I replaced that turns out to have taken care of the miniscule remaining leak (shockingly I didn't post about that) I thought it was stupid I was not replacing anything suspect while I'm this deep in so another 20 replaced on the keel today.
redneck joe
52 degree start to the day, no dew to wait to burn off. IR gun told be gluvit was at 68 in the garage. 63 degree ambient, boat shaded so same temp on applied materials.
It is done. Didn't spare, used the whole thing.
However.....
Thoughts on second coat? Budget be damned if i'm this far in I'll do it.
briangcc
If you think between the rivets you've replaced and this coat that you have the leaking licked, I'd be tempted to skip a second coat. That's just me though...no experience one way or the other.
redneck joe
Yep 100% feel good on repairs this was kinda a future proof thing plus it's almost two weeks shipping so I'm moving to the floors and the refit.
redneck joe
Had to get another quart of primer to finish the topside of bow section so added a third quart of paint as well as another grippy texture stuff. Plan is two coats topside with leftover on bottom starting at the stern section moving forward until gone. The rot started in the back and almost didn't replace the bow section but what the hell why not.
