83 - 35hp rude slipping
Captree
Just replaced the clutch dog and put it back together the right way. Held toghether great for appr. 3 hr's of run time .Put back in the water today and it started slowly backing itself out of gear . When you first put it gear it lock's right up like it's supposed to.Will stay in at low throttle but as I gave it gas it back's out. Will stay in at any rpm with slight pressure , no noise or anything just smooth cruisin... Not locking up with forward gear ???
tashasdaddy
Re: 83 - 35hp rude slipping
did you use new dog, and gears or just dog. could also be shift linkage adjustment. tiller or remote control???
Captree
Brand new dog.Kept gear. Dog and shifter were in backward's Had a very slight wear spot on forward gear but held together perfectly first time out.Boy was I pattin myself on the back for a job well done.. Lock's up nice but eases itself right out of gear now. I just have to keep the slightest bit of pressure on it and it stay's in but this can't possibly be a good thing. Guess I'll just have to pull it apart again. Cheaper than a factory rebuild.At least this time I know where everthing goes...
tashasdaddy
check you shift linkage, make sure it is right. before you open it up again.
Captree
Will do. I know I put it back together right. Forgot to check for those pesky Gremlin's !
