larry.mahoney
- Joined
- Apr 15, 2012
- 12
Over heated; top piston melted some. New piston; now to reassemble do I need to use the gasket set or can I just use permatex right stuff or equivalent? Also the O ring seals look fine should I replace them anyway?
The carbs were clean inside I can't figure out why it overheated I've had this engine for 20+ yrs. How could it run so lean to overheat? Also is there some add on for overheat lite or gauge?
Thank you experts
Thank you experts
