Ady Wright
- Joined
- Jul 29, 2009
- 15
Hi All,
first of all i want to say thank you to this site, i recently purchased on older 83 16' bayliner cuddy, with the Force 85 HP outboard, never worked on one before, i bought the seloc manual which i found very confusing until i read posts on here.
I have changed the trigger ring, both ecms/coils/ re timed it, all with help from here and i have just run it for a week here in Kentucky!
i can get around 43 MPH (via speedo on dash), is this good?
i am having smoking problems but i think this is normal, i have dropped from 16oz of 2 stroke per 6 gallons to around 5 and it still smokes.
If i run the engine at 3/4 throttle (around 33 MPH) then go to idle speed i get steam around the ouboard, is this normal? it stays steaming until i am out of the no wake zone.
i have tried alsorts of timing set ups, the 28 btdc is no good, i cannot get full rpm, at 34 btdc i get a good solid high rpm but my idle seems to be affected.
i seem to get around 30 miles to a 5 gallon tank, is this normal?
Again, thanks for this site, because of this i adore that Force outboard (i came very close to pouring fuel over it and burning it).
