john from md
- Joined
- Apr 13, 2008
- 2,184
Re: 83 85 HP force outboard idle and exhaust question
These boats were designed for ski boats. They figured that the boat would be operating most of its life at WOT. Therefore, it was designed to get the most at that speed and part of the design was surface gap plugs. These plugs operate most efficiently at WOT. They are rather bad at idle and trolling speeds. You will always get some carbon build up on them.
Most of us just clean them once a month and leave it at that. If you play with the timing or lean the carbs, you chance burning a hole in your piston.
It doesn't take much to pull them periodically and clean with scotch brite pads and carb cleaner.
John
John
