83 90hp evinrude water pump
Lonnie5
how hard is it to replace a waterpump on a 1983 evinrude 90 hp. is there any special tools u need or prettty straight forward and how long usually take? thanks
emdsapmgr
Re: 83 90hp evinrude water pump
Flatrate on that changeout is 2.2 hours. Seems high, but then a certified tech will start the engine up and run it to make sure the pump is working and that the engine temp stabilizes normally. All part of the job. No special tools required. If you've not done this before, best to have a factory service manual on hand to guide you through the process. Getting the shift linkage pin out under the bottom carb is a little tricky.
