Riverrat8428
- Joined
- Feb 4, 2008
- 37
I had to change out the mid section on my 90 Johnson this winter. I am trying to run the engine now with a flush attachment and I feel something is not right, I have water coming out of the **** hole seems cold and water out the propeller seems warm. However there is water coming out beneth the power head somewhere and a large slot in the front of the mid section right above the cavitation plate. The cylinder heads feel hot. I disconnected the large hoses fron the Cyl head to the thermosstate housing and ran the engine but no water came out.. I replaced the thermostates while doing my winter job as well as new springs and bypass valves, the water pump I didn't change as I changed the pump last year. What do you guys think? Any help guys will be appreciated.. Another question How do by pass valves work?Riverrat 8428
