Re: 83 Merc 115 hard to turnover
Any new insight on an old topic?? I have these symptoms to the "T" on a 73 merc 650 3cyl. When cranking, flywheel spins twice on third rev. starter bogs down and draws alot of power. Pull plugs and it turns like a bat out of gary,Indiana. Checked, checked, and re-checked and cleaned all starting connections. Held hand on connections after cranking to see if any were getting hot, nothing. Did compression test and all were equal. Tried to test timing, even though it should be correct ive used this motor for three years, but it wont crank fast enough to get a consistent timing "light". Is pulling the L.U. the only way to check for exhaust restrictions? Its not pulling it that bothers me,its the aligning and swearing to get it back on. Also, I dont know much about the reed valves. Do they only affect the intake side of things? My thought is that its an exhaust obstruction or something very bad internally? PLEASE help no hair left to pull!!
