83 merc 6 cly no spark
riiko155
Hi, I have an 83 merc 6cly, 2 stroke nonpowered trim and I had it running great at the end of last season. replaced the water pump and I couldn't get it to start back up due to a dead battery... so winterized it and called it a season. This year I went to try to get it to start... It will turn over very well, but I am not getting spark in any of the 6 clys. Could someone give me a rundown on what I should test? Im figuring the kill switch first, what would the best way be? disconnect the black/ yellow wires from the power packs and the mercery switch? Any help would be greatly appreciated! A Repair manual would be nice also! Thanks!
riiko155
So an update on my problem. I just got the boat to fire up. Only thing i did was pull the controller off the boat and bring it to the back so i can turn the key while volt testing... Leads me to belive theres something lose in the controller. Any common areas to look at?
jimmbo
Bad Key Switch, Loose wire that is now making contact. Broken Wire in Harness is not making contact.
