84 115 evinrude
cobia1970
i have a few posts up but i got a repair book today started to reed through it and it says to gap my plugs @ .40 not .30 :confused: my motor has also started to bog out then in at full throttle i just looked @ the starter solenoid loc above the carbs has a red valve switch on it. there is some black goop that is comming out of it on one side not alot but its starting to build up.its not wet nor will it get stuck to my finger when i touch it,its more like a silicone that is starting to dry. any answersplease that could help thanks
wilde1j
Re: 84 115 evinrude
Current recommendation:
88, 90, 100, 110, 112, 115 1979 - 1998 QL77JC4 or QL82C .030"
What manual???
The device with the red handle is the choke/primer. Should be shown and described in your manual.
cobia1970
Re: 84 115 evinrude
it says evinrude/johnson outboard shop manual could that part be bad cause of the black goop comming out?
