84, 115 Mercury problems with #2 piston
backlash49
this motor is a inline 6 cyc. When running at full speed motor starts to ping, pull back on the speed pinging goes away. Take out the #2 spark plug and it has little pcs. of alum. from the piston on it. compression is 115 in all cyc. need all the help i can get thanks Ron
MercMan82
Re: 84, 115 Mercury problems with #2 piston
This is evidence of pre detonation. Check your timing. Also make sure that the motor is not getting to hot. Overheating also increases the temps inside the cylinder as well as not enough lubrication.
MercMan82
Before some says "predetonation? What's that?" I wanted to clarify that it's pre ignition, detonation and that I do know what I'm talking about.:) Conjunction, not misinformation.
Faztbullet
Its preignition and due to either a bad idle stablizer or bia's circuit in switchbox
backlash49
thanks i took off the idle stablizer and put on two new switch boxs, it still does the same thing.
MercMan82
Did you check timing?
backlash49
no have not checked the timing, how would the timing change ???? no one has worked on this motor but me, i was told to set it at 19 deg. not 21 deg because of the gas now days ??? thanks for your help would like to find out what is causing this.
