84 15 hp Evinrude How to remove the tillers gears.
mettyfish
I got the tiller off. How do you get the gears off that go from outside the motor to the inside. I don't see any set screws or pins?????? Help. thanks Mettyfish
marinemech1
Re: 84 15 hp Evinrude How to remove the tillers gears.
The one in the handle is held in by a screw that goes through handle.(Rubber grip may have slipped feel around for a hole and reposition grip as required).
The motor side has a retaining ring holding it on the back side of gear...its easy to remove and a bit of a game to put back on.
Hope this helps and good luck.
Wayne
