1983 Evinrude E175TRLCTD
Best way to describe it is, on muffs at 1100 RPM, thru the prop exhaust goes ba-ba-ba-ba-ba-pompf-ba-ba-ba-ba-ba-pompf.
The pompf repeats fairly regularly about every 3 to 4 seconds.
Slightly higher puff of exhaust smoke is also emitted during the pompf.
History.
New thermostats. Temperature perfect.
Runs great, but would be hard starting after hot. Wanted to stall. Had to choke/primer it if I wanted it to start hot right away. This in water that was 83F or higher. If idling in no wake zone for a while, RPM's needed to be kept up near 1000RPM, otherwise it might pompf and stall.
Compression 90PSI on all cylinders.
Can run WOT for extended periods, 5400 RPM's, pushing Wellcraft V20 at 43MPH, so seems great running at speed.
Did decarb a couple times. No difference.
Rebuilt carbs. They looked great, but did them completely anyway. No difference.
Performed link and sync.
Now testing in 70F water, and after a good 60 minute open water test run, ending with 15 minute river idle speed, checked spark plugs and all looked great except #1, which was blacker than the rest. Replaced all spark plugs with new UL-77V. #1 coil looked like a black tar substance on block touching coil, so thinking coil might be leaking (even though substance was dry), I replaced #1 coil. Again, no difference.
Using a grounded test light probe, while running on muffs at 1100 RPM, poked through each boot at plug, and it seemed that #1 grounding nearly eliminated the pompf, while the pompf was still seemed to be present grounding each of the other cylinders. Leads me to think it is something related to #1.
What do you think I should check next?
Thanks.
History.
Thanks.
