'84 70Hp Lower unit play
Jeepman252
I have the lower unit off to replace the water pump. I noticed what seems like excess play between the drive shaft and the prop shaft. When I hold the drive shaft from moving, I can turn the prop shaft about 80-85 degrees before feeling resistance on the drive shaft.
This seems excessive for any right angle drive. Is there a spec on this? Should I be concerned? I have never had metal shavings in the lower unit lube.
Thanks for your help!
Chinewalker
Re: '84 70Hp Lower unit play
Completely normal. What you're noticing is the play between the lugs in the clutch dog and the gear lugs. There's a sizable gap between them to allow space for them to engage.
Jeepman252
Whew!!
Thanks for the quick reply Chinewalker!!
I'm a maintenance mechanic by trade, but have never attacked a lower unit. I'm glad I can just put the new water pump on and put her back together!
