trevornewell
Thread starter- Joined
- Jun 14, 2009
- 22
we are having trouble adjusting the idle on my dad's boat. you have to rev the motor up high in order to get her to not die when you put the motor in gear. from what i have read i think the idle should be set in water and in gear. please correct me if that is wrong. this is one problem.
the next issue is that when the motor is running at idle with no load if you open the throttle a little say not even 1/4 the rpm are fine, but when you pass this point the motor revs like it has been given full throttle. i have the owners manual and still cant find any solution. please try to help if you can.
