- Joined
- Jul 23, 2011
- 53,275
Pm me your emailIs there a good manual online or that a guy can purchase to go through the trans?
I found this confusing to follow. First you said it’s a 3.0 Volvo. Then next it’s an OMC Cobra. So which is it? If the Cobra and no oil over the upper gears you will need a rebuilt upper gear housing at the least. Those units take approx 2 qts of gear oil and have to be filled correctly. If you want to test the engine pull the drive and hook up water to the impeller and run the engine. If it doesn’t lock up then your problem is the outdrive. Reman gear housings are generally available for the Cobra drives you have to make sure the drive ratio is correct.
No, a mercruiser engine and drive was originally bolted into your boat. that is the only other drive hole that the cobra could fit. By the looks of it, the prior owner found an earlier motor and bolted it to a later drive and installed in the boat.So a cobra originally was bolted to a mercruiser eng in this boat? So is this most likely a GM, VolvoPenta, or or mercruiser engine? I was just looking and it looks like the lower end is a lighter grey that the upper.
No, there wasnt even a trace of oil in the upper case.
engine serial number from GM is, however the OMC serial number will be on a stamped tag just above the starter boss.So the serial numbers are the ones stamped into a machined part on the block? Where would I be able to find a manual for the cobra?
