84 Merc 115 I6 rectifier
Volphin
The rectifier failed on my old fishing boat. It has an 84 Mercury 115 I6, with rectifier PN 8M0057404. I can't seem to find this part. Has it been superseded? If so, to what?
Volphin
Someone in the past had put the wrong reg on the engine. Proper PN is 8M0058226 for those looking in the future.
Chris1956
That Mercury rectifier is simply a full wave bridge. You can save yourself 90% of the cost of an OEM one and get a better part from an electrical supply place. Radio Shack used to carry them, but alas.
Pick out a 15A full wave bridge rectifier, and make sure to ground the -DC post to the block. The red wire goes on the +DC post, and the two yellow wires and the grey wire go on the other two AC posts.
Volphin
Aaaannnndd, we only lasted 1 trip before the tach died. I haven't checked the output yet, but I'm 99% sure we blew another. What can cause this failure?
Chris1956
Rectifiers will blow if they are disconnected from ground or the battery, and the engine is running and the stator is putting out battery charging voltage.
Volphin
All connections to the battery are tight... the boat has 2 batteries, one for starting and one for trolling. The trolling battery is removed. I do use a cut off switch on the starting battery as it was slowly draining over time... 2 weeks or so. Here's a photo of it.
Chris1956
OK, not sure what to say. Rectifiers usually do not break if they are connected properly. You can check them with an ohmmeter. Search for the procedure to test a bridge rectifier. You check each of the 4 diodes for continuity one way (on the meter), and no continuity the other way.
