'84 Merc 150 V6 - Is my block destroyed?
MAtkins
It's taken some time but I've finally got my block back from the machine shop.
It's bored .030 over on all cylinders. The machine shop indicated no problems.
While cleaning the surfaces that the heads bolt onto, I noticed a small scratch.
Does this render my block destroyed?
Faztbullet
Re: '84 Merc 150 V6 - Is my block destroyed?
Is that a scratch or crack? If a crack it will be cheaper to find another block...
wired247
Which scratch are you talking about? The one at the 8:30 ish position on the top of the bore and edge of the water jacket looks like a scratch. I wouldnt worry about that one. The other one at bottom of the picture on the outside water jacket looks more problematic but its hard to tell from the pic. If it is cracked and it was mine I'd weld it and dress up the sealing surface and MAYBE have it decked if I couldnt get it straight by hand.
MAtkins
It's a hairline scratch, not a crack.
It's really small. You can see it real well in the pic because the sun hits it just right.
If not for that I might not have even seen it.
I see it pretty clearly in the pic.
It's almost @ 9:00 and goes across the top of the bore and also the outside water jacket wall.
It's a perfectly straight line.
wired247
Pretty much a total non issue. Go over the deck with a sanding block or get it decked for $50 if it really bothers you. Its the one at the bottom of the pic that looks worse from your pic but its probably just a casting flaw.
MAtkins
thanks wired.
Does it look clean enough to use or do I need to keep scrubbing?
I'm using a metal scraper, scotch-bright heavy duty & mineral spirits.
You mentioned a sanding block?
I've been told numerous times *not* to sand it at all.
Can I use sand paper? If so, what grit? Wet or dry? ????
wired247
You dont want to take much metal off. Just clean it up a bit. Check with a straight edge as you go. Nothing too coarse. 180 grit at the coarsest. To be honest its probably fine the way it is.
MAtkins
OK thanks.
I'll probably run something real fine on a block, very lightly and call it good.
Faztbullet
just true it up as wired posted or have it decked, you can safely have .020 cut off deck. Odd that shop didnt surface it boring
MAtkins
They didn't impress me much.
I got it to my dealer a week before Christmas and they didn't get it back to him until the 24th of January.
They jacked their prices up till my bore job was almost double my original quote.
They extracted a bolt for me & charged me $42.00 for that but they didn't clean *anything*.
Honorary Supreme Mariner
It almost looks like mark / scratch left by a boring bar tool bit.------Remember you can not just clean up this spot there.----The whole surface across the 3 cylinders must be flat.
CharlieB
As already posted, you can safely deck .20 off that deck, slightly raising compression, and power. But you must do BOTH sides the same.
I'd drag a fingernail across it, if it 'catches' then deck it. If not, clean and reassemble, it will be fine.
Note, the critical portion is the steel liner, not that alum around the liner. If you can snag a fingernail on the liner, deck it.
