84 Merc 90 inline 6 overheat horn??
bigtrout1949
Got this motor a while back. When I started it in a tank it stopped pumping water. I never heard the overheat horn. Replaced the impeller. Runs all day with good water circulation. Does anyone know it it even has a horn??? Used to be able to test horn by inserting key into slot in remote in similar motor. Help!!
jimmbo
Re: 84 Merc 90 inline 6 overheat horn??
There is no overheat horn or temp sensor on this engine. It does have a tell tale on the starboard side that will show if the pump is pumping, unless it has plugged up.
Faztbullet
You can add a horn and overheat sensor but its overly priced.
