Mousejockey
- Joined
- Aug 18, 2011
- 36
I'm working on a friends boat, Tilt was 'clicking' on him and he replaced the solenoids, and it worked. Then he couldn't get the drive to go up. When trying I could hear it spinning. Disassembly of the system showed what I suspected. The roll pins for the worm gear had sheered and the shaft was spinning freely. Ordered a new shaft, pins and gasket/seal kit. Cleaned clutch pack, reassembled and the clutch wouldn't turn (clutch drive only, no worm gear/shaft). Installed a homemade thicker gasket and the clutch now spins freely(Clutch drive only, no worm gear/shaft). Now, when I install the new shaft with the nylon washer and worm gear the clutch will not move. Period. If I install the shaft only, the shaft spins free, with the worm gear no movement. I can adj the tension on the clutch pack to where it will turn, but the shaft does not, tighten the clutch and all is frozen up. Tried the worm gear alone, no shaft, and it didn't seem to want to spin, just move in/out as the clutch gear rotated.
What in the heck am I missing here??
