85 150 ?
mike duff
I just got boat engine runs fine first thing out but after while or running slow will not run full out sometimes by pushing in choke takes off and runs fine. Any help pleased:)
Joe Reeves
Re: 85 150 ?
What is the model number of that engine?
(Compression & Spark Test)
(J. Reeves)
1st - Regardless of what problem one might encounter, always start with the basic troubleshooting procedure. Check the compression which should be in the range of 100+ psi (somewhat less on the smaller hp engines) and even on all cylinders.
2nd - With the spark plugs removed, rig up some type of spark tester whereas you can set a gap to be jumped. On magneto ignition systems.... and also the Battery Capacitance Ignition system OMC engines from 1968 to 1972, set the gap to 1/4". On the solid state OMC ignition systems from 1973 to the present, set the gap to 7/16". The spark should jump the gap with a strong blue lightning like flame..... a real strong blue snap!
If there was no spark, on engines from 1973 up, disconnect the RED main electrical plug at the engine. Remove the s/plugs. crank the engine via the starter solenoid (jumper bat term to small 3/8" term nut, not the ground nut) and observe spark. If spark is now okay as stated above, the usual cause is a shorted ignition switch.
If the above checks out as it should, and the engine dies out when throttle is applied or won't idle, it is usually due to one or both of two things. The carburetors are fouled, in which case the cure would be to remove, clean, and rebuild them..... or the timer base under the flywheel is sticking which would result in a retarded spark.
To check the timer base for sticking (Engine Not Running), spin the prop to align the shifter dog with forward gear and while doing so, put the engine into forward gear. Now, while watching the timer base, slowly apply throttle clear up to full throttle. The timer base should move smoothly all the way up against the black rubber cap that is atached to the end of the full advance spark setting screw. If the timer base sticks, find out why and correct that problem.
Usually any sticking of the timer base is caused by one of the four retaining clamps being slightly too tight. Putting a very thin washer under the clamp cures that problem. Some boaters use a thin screwdriver to bend the clamp upwards slightly but I prefer the thin washer. The sticking can also be caused by having a faulty stator start to melt down, resulting in a sticky substance dripping down on the timer base nylon retaining ring.
mike duff
Re: 85 150 ?
Did compression check all around 70 we are about 10000 feet above sea level plugs have no gap? If compression bad would it run fine early? have read other links what is sinc and link? Sorry so many questions new to boat ownership. Thanks for all the help.
mike duff
Re: 85 150 ?
Model number is J150TLCRD Sorry so excited to get answer missed first part Thanks for any and all helpd:)
tashasdaddy
Re: 85 150 ?
yes compression can cause many problems, so can spark. thats why it is Joe posted the thread . we need to know the basic health of the engine, then go from there, linc & sinc is a long progressive step (but rather simple) by step setting the the electric timing to the timing of the carb so they work properly together. it is in the OEM service manual, which you need to purchase buy to original for your engine, not an after market manual. the fact the engine picks up with the choke points to dirty high speed jets in the carb. after cleaning and reassembling the carbs with a new rebuild kit. you need to do the linc n sinc.
mike duff
Re: 85 150 ?
did spark test good sharp blue. How much will compression very with altitude. Found SELOC manual looked for OEM did not find place to get any help link would be great thanks for info so fard:)
