Re: '85 90 hp drive shaft seals
The prop and the forward thrust washer will come right off. there is a special tool that will allow you to remove and install the shaft seals without removing the bearing carrier.<br /><br />As expensive as that tool is, I would just pay a shop the minimum charge to replace the seals using the tool. To drail the oil, change the seals, pressure and vacuume test and refill the unit can't take more than an hour.
