85 90 hp evinride carb linkage parts
simplydave
twin carbs, upper/lower, are connected with a ss rod with a nylon piece that goes through the butterfly valve actuator and holds the rod.
any idea where I can get one of them? I need just the nylon piece. It's upside down "L" shaped, open on the back and the bend in the connecting rod goes through it.
simplydave
I described it incorrectly, it was a piece about 1/2 inch long, 1/4 inch wide with a hole through it and an area to put the ss rod. I said the Saint Anthony prayer and he showed me where it dropped off at and laid.until I found it. It was in the motor pan under the carb.
emdsapmgr
You can check out the factory exploded parts list to identify the part you need for your engine: epc.brp.com. You may be referring to the 313329 nylon retainer, found on the intake manifold diagram.
