tysdad2010
- Joined
- Apr 2, 2012
- 88
Lost spark on 4 cyclinders on 1985 Mercury Blackmax 150... 3 are down on one side and middle one on other side is down ...what would cause that problem?
Pull all the spark plugs and retest.. If spark returns its low cranking speed due to bad/weak battery, corroded ends or bad cables or weak starter. If it does not return disconnect the white/black wire off the switch boxes and test , if ok leave the idle stabilizer disconnected and just reinstall jumper. If ok the stabilizer was bad or if not the bias circuit in packs may be bad. Also could be a trigger but not as likely... maybe a stor if above test check out..
