85 evinrude 50 hp tilt trim crunching noise.
snake eater
I have an 85 evinrude 50 hp with power tilt trim, I had to replace the motor and reservoir, I put the new fluid in it, cycled it up and down a few times. The problem is going up it makes a terrible crunching noise and the fluid is frothy with air. It sounds great coming down. any ideas? this is my first tilt trim experience.
honald112
Re: 85 evinrude 50 hp tilt trim crunching noise.
Sounds to me like you need to bleed the air out. Cant compress air.
D
DJ
Guest
It is low on fluid. They are self bleeding. Check the system with the unit all the way up and BRACED.
