Re: 85 evinrude 90 hp
Check compression.... should be approx 100+ psi and even on all cyls. What are your readings?
Spark (with spark plugs removed) should jump a 7/16" gap with a strong blue lightning like flame..... a real SNAP! Does it? NOTE.... the 7/16" gap is important, checking spark simply with the spark plugs is a waste of time.
Spark plugs should be Champion QL77JC4 plugs, galled at either .040 or .030. Try the .040 setting first, then compare with the .030 setting if you so desire.
On a flushette, considering all of the above is as it should be, the idle rpm should be 1000 rpm for a 20" shaft engine, and 1200 rpm for a 25" shaft engine. With this setting, the idle will drop to where it should be when in the water.
