85 evinrude vro dosnt charge batt when running
sparkyclass1
I may have hooked the cables up wrong one. Ive seen other post about something called a RECTIFIER cant seem to locate it on my motor. Is it possably my motor dosnt have 1
D
DJ
Guest
Re: 85 evinrude vro dosnt charge batt when running
Hooking up the battery cables backwards will certainly "pop" one.
You don't say what horsepower.
emoney
(pics or it didn't happen). Actually, in this case, posting pictures would help folks help you.
sparkyclass1
It is a 70hp and here are some pics
stylesabu
Master Chief Petty Officer
neither pics came through
sparkyclass1
retiredfornow
Follow the yellow wires from that vertical terminal strip and it will lead you to the rectifier. Let us know if it's round or squarish.
sparkyclass1
the yellow wires lead in to the fly wheel can you just take that off our do i need to like make the position
sparkyclass1
They go in to the black plastic and in to the flywheel
sparkyclass1
if the tach dosnt work is that the stator or could that be the RECTIFIER to
Fed
Looking at your 1st picture I can't see anything connected to your yellow wire from the stator.
sparkyclass1
i dont think there is even a RECTIFIER on the motor
sparkyclass1
i looked i just dont see any thing that looks like the pic they show
sparkyclass1
it says that the rectifier is # 27
convert
Fed
I think #27 is the bolt, look at #43 it should have 3 wires coming out of it that connect to the terminal strip.
sparkyclass1
i think i solved the mystery 1 pic i found on the web just to the left of the terminal block there some thing that looks like the pic in the book
in the 2 pic you can see it is not there
the power of the web thanks for all your help
would the rectifier not being there make the tach not work or are there other issues
sparkyclass1
your right #27 is a bolt
maineboat
Hi Sparky,
Don't mean to hijack your forum, bit I have a similar motor, Johnson, and I have a question. What is the box above the carbuerators? Is it some kind of a tool box? I have seen it on a lot of other similar year/horsepower motors, but I cannot find it in any parts books.
Thanks - maineboat
