Re: 85 H P Force ????
All boat motors are gas hogs, some a little more so. <br /><br /> As a general rule of thumb, you can figure gas consumption by:<br />#hp / 10 = gallons per hour at wide open throttle.<br />THis formula has sparked much "discussion" in the past, but lets say this would be a maximum figure and it depends on boat-hull-weight- sea conditions-engine design- age and condition of motor- AND throttle position.<br /><br />Also, most parts for most motors are expensive. The trick is to not buy something with a dark history, and then maintain and uses it properly so you don't have to buy parts.<br /><br />Good Luck.
