reptileguy
- Joined
- Jun 16, 2011
- 48
1980 85 hp evenrude v4 not idling less than 2000 rpm. The carbs are non adjustable and have had rebuild kits put on. Timing was set at 4 btdc but pretty much useless until rpms are down. I can't set it the advance way as under load in water it just backfires and misses a lot when I throttle. I confirmed reed valves are good and installed new manifold to crankcase gasgets and carb gasgets. I did notice one of the check valves was leaking fuel under the carb, further inspection showed it was broken so replaced with a brass check valve as plastic is not available. Now it won't idle at all. Can someone confirm which crankcase vent hoses go where as well just to confirm thanks
