SCduckhunter
Thread starter- Joined
- Sep 9, 2013
- 64
Hi all...I have an 85 Johnson 15 HP that I rebuilt back in October.. I hunted a lot with this boat without any issue.. I run it about once a week to 10,days in a barrel. The other day while it was running(and fine),I took the cowling off. I touched the block checking for temperature and to.my surprise it shocked me!! I checked all the grounds for good contact and sduch and didn't find anything amiss...it is still running fine at this point bit I don't want to burn up/ out anything...I remember having issues when installing the coil packs..I couldn't remember the sequence of how the washers and bolts went through the contact plate...I believe this is where my problem is...however it may not be the issue so I'm going to start with that...any advise?, and what's the proper sequence of the washers to coil pack with mounting bolt when installing? Thanks all
