Re: 85 Johnson 50 running hot
What kind of thermostat did you install and are you sure it is installed correctly? I've heard some of the OMC stats are engineered poorly and lack a small groove to allow water to pass through to heat and open the stats.
If you are sure your stats and impeller are all good, I would wonder if there is an obstruction in the cooling jacket, you may have to pull the head and look.
It's also possible you are getting a false positive. Have you checked the temperature of the head when the alarm goes? I suggest an infrared temp gun.
