FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Clean all battery connections. Engine side, and battery side. Get good battery. No wing nuts. Use a wrench. Ohm battery cables, they do not last forever. Solenoids go bad as well.
it it was a battery issue- for a new battery and it start and runs...
NEW PROBLEM
It idles fine high and low - goes into gear and runs well ... even heads toward top speed and gets really going and then does out.
after that it runs on low speed ok but when I try to go full throttle forward it wants to choke out and die.
we had a dry rotted field hose from where the couple meets the motor to the fuel pump(?). And we replaced it with a piece Of hose from the fuel line with the pump bulb.
When it starts to die push the key in and let the primer shoot a little fuel in it and see if it takes off. If it does it's probably time to go through the carb. You can also have a buddy pump the primer bulb and see if it picks up. If it does then you have a weak/bad fuel pump.
