85 Johnson V90 w/ Power trim
64osby
Ended up with hijack in a different thread, trying to see if anyone can tell me if my motor / tilt is factory or an add on by the PO or a Marina?
Model # J90MLCOS.
This is the hijack
Originally Posted by ezmobee
My esteemed college 64osby is incorrect about the location of a pump motor. It is within the bracket assembly.
EZ thanks for the compliment and the slap down. :beaten: The PT&T is different than what I have.
This is my '85 V90. Has power TILT only and the pump is outside.
From EZ
That's a pretty oddball setup for an '85 you've got there 64. Pre-'78 I'd understand but I thought those tilt only units went away much earlier. Even my '81 has the more modern style completely integrated into the bracket unit.
EZ - Did a little checking and came up with this.
http://www.**********/parts/search/B...NLY/parts.html
The unit doesn't show up under any parts manual for a V90. The one above is for a 65HP. Parts break down show it as made for 1984/85 motors.
It would be interesting to learn if the '85 V90 was ordered with this as an option or if the PO added it.
Oddball:eek: Well yea um:watermelon:
RRitt
Re: 85 Johnson V90 w/ Power trim
look up the factory trim on a 1985 65HP WTL engine. Looks like the same trim system to me.
emdsapmgr
Go to the "accessories" tab on the 1985 factory exploded parts diagram website. For 1985, the factory lists a power tilt assembly for the 65-115 hp engines. Identical to the one on your engine. Original part number: 173669. It's still available as a special order only.
64osby
^^^ Accessories - I've looked at the parts diagrams a thousand times and seemed to have never realized it's there.
If it was a snake.........:embarassed:
1985 Power Tilt
Thanks guys
emdsapmgr
That same snake has gotten me many times...
