85 merc 115 inline 6
bigdaddy08302
:confused:Looking at a used motor...85 115 merc inline 6. Did compression tests and found the following...#1 (top) 74 lb, #2 100lb, 3,4,5,6 112 lb. What could be causing this and is this a really expensive fix? Any help is greatly appreciated.
douglas1978
Re: 85 merc 115 inline 6
depends are you going to do the work yourself or pay for it, is the motor free (lol) could be the rings are stuck, burnt piston
bigdaddy08302
It turns over..not free but relatively cheap...he was asking 600...now I suppose I have a bargaining chip but I am not sure how deep I am getting here. I cant do the work myself.
Faztbullet
Top cylinder (#1) is damaged and yes it could get expensive if you take to a shop. For your compression test it looks like engine had a weak impeller and ran hot as #2 cylinder is low also. You can get a good idea of cost till you tear it down to inspect it.
douglas1978
walk away then i've seen shops charge over 3 grand for rebuilds look on craigslist i got lucky last feb got a 115 for 500 bucks great motor 2
bigdaddy08302
Id like to find another...good motors are harder to find than I thought.
$600 for that motor is way overpriced. I would look for a newer one, in good shape for the same price or a few hundred more. I bought a good running '93 Merc 135HPV6 for $1k some years ago. Way better motor, IMHO, and I owned a '77 Merc 1500 for 25 years.
Gomer50
This looks to be one tired motor,I think $600.00 is too much unless you really want to rebuild this one (project motor).
