Hello i just bought a 1985 sea sprite with 140 mercruiser with a cylinder compression of 1-125, 2-125, 3-150, 4-125... motor idles well but are these numbers okay or should i be looking to rebuild the motor in the next couple of years?
I do not understand why one cylinder is high, normally dont do that.
any clue on why one cylinder is higher?
I was wondering why one stayed high with three low. Most times one goes low valve or ring/piston. Then two low cylinder head or gasket. Three low one higher or normal is just kinda weird.It isn't, he has 3 that are low, the 150 is normal.
