85 MR outdrive, what grease goes to what zerk fittings?
weider1717
I assume there are different grease types that I need to put into the different zerks.
So, in other words I don't need to buy one type of grease and grease all the fittings, I assume there is a right and wrong grease to whatever your're greasing on the outdrive.
question is what grease goes where? where do u put 2-4-c grease? and what grease do you put elsewhere.
thanks
ziggy
Re: 85 MR outdrive, what grease goes to what zerk fittings?
for my 1 drive. i use 2-4-c on all the grease fittings on the drive except the gimble brg. zerk. that one gets mercruiser gimble brg. and ujoint grease.... don't know if you have a zerk for the coupler. i don't. if i did. that one would get mercruiser spline grease on it...
weider1717
Not sure it's a MR drive..it's 99% the same thing as an alpha 1 gen one. Has the flat top and all.
ziggy
go to service manual #6, pp. 1B6.. the whole B section is about maint. schedules. pp 6 covers your zerks on your drive and what to apply to them...
weider1717
thanks, where on here is the service manuals?
ziggy
http://forums.iboats.com/showthread.php?t=288430
it's the adult only sticky at the top of the i/o forum.
go to #9 and get #6 and choose your poison for your engine..
read up on the other items in that sticky too. a whole gob of relevant info in that thread..
