85 trophy 22 ft
Eddie Ray
22 ft trophy with Volvo four banger,270 out drive. What can I expect for a top speed?.where should I limit it as far as running rpms. Heard it probably won't plane,how bad will the gas mileage be if it won't plane. Seems like a solid boat,good shape for her age. I'm older,and not into speed. Just fishing and diving. Just want to get there and back
Thanks Eddie
Fireman431
Re: 85 trophy 22 ft
Your engine is probably in the 140HP range. On a 22' boat (you didn't mention if it was a bow rider, center console, or walk-around cuddy (all are different weights). If trimmed properly, you can probably expect 28-30 cruising speed and around 38 at WOT. If it won't plane, your milage (and the plowing wake) are going to be terrible. Your RPMs should be around 3000-3200 cruising, but I don't know what your WOT RPM is.
