I have a (new to me) 85 bayliner with an AQ125A volvo penta and it has a couple problems.
1. Motor dies at about 2000 rpms. It idles great, it revs high and runs high rpm great, but if I throttle in between 1000-2000 rpms slowly, it dies. It starts right back up no problem. When it dies it doesn't sputter, its like I turned the key off.
2. There is no water in the heat exchanger and it is slowly overheating. I replaced the impeller and thermostat and ran it with earmuffs. I think that because it has the closed coolant system, it kept it from overheating right away, but it hit 180 and then up to 200 after running for 10-15 mins. I shut it down then and repeated it later.
3. Leaking oil onto the fanbelt. Valve cover gasket, cam seal, and crank seal are the only three options right? Am I missing something else? I can't see a leak anywhere but it is making a hell of a mess. I just changed the engine oil and the oil is perfectly clean on the dipstick while the oil leak is black dirty oil. Even after running for 15 min the dipstick is still showing nice clean oil, which seems wrong. Oil pressure is 40 at idle and ramps up higher with rpms, 80psi at 5000rpms.
4. Overcharging at high rpm. I saw the gauge hit 16volts at 5Krpm. I figure this is just a regulator problem but didn't want to leave it out.
Any help or ideas would be most appreciated.
I'll try and take another look for the oil leak, but if its a cam/crank seal then I'm going to have to take it in since you apparently need a couple of specialty tools to remove the pulleys and seals. If I can solve any of these issues before I take it in then maybe I can save some money.
Thanks,
Jeff
Thanks,
Jeff
