850 merc 73 thunderbolt
Hotrod758
Buddy of mine has a 150 merc blackwater with a new stainless prop will this fit my motor? I don't know alot about props the one on mine is a 3 blade stock not sure of the pitch but I didn't know if his would work on mine or not
Hotrod758
I did get info on the prop it's a m 14 ¼ x 24 turbo 3 blade stainless 15 spline idk if it will fit or not any help would be appreciated if it won't not a big deal but it would be a free prob just curious if it would fit
Props attach to the motor.-----But they fit the boat !---What prop is on your motor now ?--What kind of boat ?----Typical pitch for that 85 HP would be 17".-----Motor might struggle to turn a 24 " pitch.
Hotrod758
It's 88 bluefin bass dominator and idk what's on there now I'll take it off and check it out
harmanoff
RPM's will tell you if its the right one, along with other things. I got a 02 60HP Bigfoot, started with a 15pitch prop, and at WOT i would surpass the recommended max RPM. went to a 17 and at WOT i now sit at a comfortable 5300 rpm!
Chris1956
Most Merc 150HP Black Max motors have the larger gearcase. There were a small number of V6 motors with the smaller gearcase.
Your 850 should have the smaller gearcase. The splines will fit, but the hub will likely rub your gearcase, if it has the larger hub. I also doub't you will be able to spin that 24P prop to max RPM.
