centerline
- Joined
- Sep 8, 2008
- 57
after pulling the 1975 85hp motor and wiring out of a donor boat, I placed the motor on a motor stand and had the engine tuned, new impeller, lower unit oil changed and running great and dependable....
now, after installing it all in a newly reconditioned glasspar hull, and connecting the wires, cables, steering and trim system, the engine wont crank over with the key switch.....
the red wire on the start solenoid is hot and the ground is good, but what I cannot determine is what wire gives voltage to the ignition switch so that it can power the start relay and supply power to the volt gauge....
I would have thought there would have been an ignition supply wire stacked on the start solenoid lug with the batt hot wire, but there isnt.....
.........is there a fuse somewhere that may have blown?
.........what color wire is the hot feed into the ignition switch?
.........where else should I look for the problem?
