85HP Force Lost Power
LarsMN89
1989 Force 85 hp lost power while at high speed, gradually could only get 4-5 mph at full throttle
Last Saturday I was trolling for about 3 hours with a couple stops for casting. I then went up to full throttle to clear out the motor. I ran for about a 1/4 mile then turned around to go to the landing. After turning it gradually lost power until I could only get bout 4-5 mph at full throttle. It would not idle. At the dock I tried squeezing the priming bulb but there was no effect. At home I checked the compression of each cylinder, top to bottom: 130, 135, 130. Spark plugs were all oily and wet with gas. I checked the fuel pump and filter screen - they were ok. I removed the in-line filter and it was clean. The only odd thing is that when I ran it in a water-filled tank there was oil in the water! I checked the lower unit and the fluid is clean, no foaming. I don't see any lower unit leaks. It cranks strong and starts good but needs to be on full throttle. I'm at a loss as to what to check next. I'm thinking the oil in the water tank is from unburned gas/oil mixture in the exhaust (?).
jerryjerry05
The linkage, check for loose or broken connectors.
When you squeezes the ball, did it firm up?
Check the fuel pumps diaphragm.
Check the hoses for soft, mushy or cracked lines.
The inline connectors they can go bad and suck air.
​Yes the unburned gas/ oil could be from that.
Or the diaphragm is bad and sending all the fuel into the water???
pnwboat
Check for spark on all the plugs. If spark is good, and you're seeing evidence of excessive gas/oil on the plugs and in the water tank, it might be like Jerry mentioned.....torn fuel pump diaphragm that's dumping excessive gas/oil mixture into the motor which shows up in the water tank.
LarsMN89
Update...
I ordered a new fuel pump diaphragm and gasket last week. Received them today and installed them. Setup the water tank and ran the motor. Everything seems good: idles ok and increases speed as it should. Took it out to a nearby lake and it ran great at idle, low speed and full throttle.
Thanks for all your help.
