85hp force
rayderz1
I HAVE AN 83 BAYLINER WITH AN 85 HP FORCE WHEN I LAUNCH IT STARTS EASY BUT WHEN I TURN THE MOTOR OFF FOR ABOUT 20 MINUTES AND TRY TO START IT JUST TURNING THE KEY IT SOUNDS LIKE IT BACK FIRES THEN IT WON'T START IT LEAKS GAS FROM THE FRONT OF THE MOTOR I THINK IT FLOODS ITSELF CAN ANYONE HELP ME ?:confused:
chitownborn
Re: 85hp force
if its leaking from the front of the motor, might be time for a carb rebuild? sticky float, worn needle, dirty, or floats out of adjustment, also check your fuel lines
